Advice Please
steve todd
Dec 15, 2017
82
61
brisbane
Does this mean if if mix 39g to 1l then dose 20ml per week is good for kh2p04 I worked it out right
Cheers
steve todd
Dec 15, 2017
82
61
brisbane
thank You for helping me to better understand EImethod
If I get.
Fe-DTPA And need to dose at 0.2 mg\L what does. This convert to in mls
Cheers
Allwissend
Super Moderator
Moderator
575
293
63
www.intuitiveaqua.net
So just to confirm, the mix you have is liquid? If yes, add 2 ml to the aquarium directly or put 2mL in 18mL water and add 5mL, 4 times per week.
No need to dose the flourish trace anymore, by and large.
Also make sure that the mix only has traces and no ammonia, urea, etc
Allwissend
Super Moderator
Moderator
575
293
63
Then to 80g add RODI until the total volume is 1L
Check if it fully dissolves in a few hours, let me know if not.
20mL will add 0.2mg/L to 150 gallons, so you can add 5ml 4 times per week.
It may help to add some(2-4l acetic acid(or filtered vinegar) to prevent mold
Allwissend
Super Moderator
Moderator
575
293
63
You can get a canister of distilled water from many supermarkets, usually in the auto section.
With tap you risk microbial contamination and other reactions.
steve todd
Dec 15, 2017
82
61
brisbane
Help can’t get rid of this algae
Allwissend
Super Moderator
Moderator
575
293
63
You seem to have a good mix of debris, diatoms and cladophora. Blow away the debris into the filter or clean it as much as possible.
The brown algae will go away once the tank is a little more established and when nutrient levels are higher. Harder water seems to favour them.
The bad news, cladophora will not go away on its own. Spot dosing with excel or H2O2 will prevent it from spreading, but you will have to be very rigorous.
