Adding nitrates to substrate
jerime
78
Assuming I'd like to add nitrate to my substrate for additional fertilizing, would it cause any problem, such as being converted to nitrite and diffused to the water column?
803
Re: Adding nitrates to substrate
No, it will not form NO2 or NH4 unless the tank has soil or extremely heavy loading from fish waste, it will also diffuse out fairly fast, in a day or two.
The NO3 we add gets into the substrate also.
Some might be denitrified.
That's something I'll get at shortly in the coming month/s.
jerime
78
Thanks tom. Waiting for your articles every month :)
If my tank does have soil in it, as you mentioned, what happens then? is there a way to avoid such problem (besides not fertilizing it :) ).
Thanks.
803
Just leave the soil, try not to much things up when replanting.
It'll decompose(which is not a bad thing if it occurs slowly) and if you want, you can vacuum it out in stages(1/4 of the tank each weeks etc)
