Hi, I want to ask you about my idea of adding metal chelates to the aquarium. I mentioned the information in another thread that chelates break down with light under 520 nm and chelate again, the problem is that in water with higher DOC they chelate with DOC and that is the problem with the occurrence of BBA in my opinion. To avoid this, it would be interesting to add chelates only during illumination above 520 nm or in the evening after the lights are turned off, when the chelate remains in the original bond. When asked how much, I would say enough so that there is no chelated or free iron in the water in the morning /Measure with a test that also measures chelates, for example Seachem, JBL..../ , this will guarantee that the chelates in the water will not break down and the metals will not chelate with DOC. Plants are able to receive metals in chelates, so it should not be a problem and the chelate will probably last longer in the plant before it breaks down and the plant slowly consumes it. Further addition would depend on the condition of the plants and their manifestation of iron deficiency and not regularly. Plantex CSM (also in B) is only an EDTA binding, Tenso cocktail is a combination of EDTA DTPA. At a pH above 6.5, about 80% of Fe-EDTA breaks down within 14 days. As a guide, they should be added as I described above, every 10-14 days. Observations with this system and with other chelates will be interesting. I'll give it a try when I'm done with my elaborate experiment. However, I don't have much BBA in the aquarium on plants anymore, and I don't have very demanding plants either, and maybe someone can try it for me. However, cleaning and removing infected leaves with water changes is necessary, it probably won't affect the already formed BBA, but I think it will definitely affect the new BBA. Write your observations here.
Important:
However, the night dose of microelements must not be very high, / rather give half the weekly dose / so as not to limit the activity of bacteria.
Read this story Detritus Mulm : https://barrreport.com/threads/iron-toxicity.6494/
A large dose of microelements at once, in the morning Fe 0 ppm in the water, but the ammonia rose !!! Everything was absorbed by plants and biofilms and it was bad.
An excellent experiment with chelates that can help determine the dose: https://www.ukaps.org/forum/threads/plant-deficiencies-and-the-fe-experiment.71191/
My opinion is that Fe gluconate may be more effective in chlorosis, however, among other compounds, it can chelate with DOC and this will be encouraging for BBA.
I think that by adding more CO2 with the EI method, we force the plants to high consumption of nutrients and microelements, the problem is that we cannot direct the addition of micronutrients not only for plants, but also for bacteria, and especially young biofilms suffer from their toxicity. Therefore, it is important to find a balance between fertilizing plants and maintaining good bacterial function. Sufficient oxygen in the aquarium is not the only factor for the good activity of biofilms in the aquarium, but also the amount of pollutants limiting their activity.
Important:
