Add additional K2S04??
nwfishinfool
Jun 22, 2007
45
62
Seattle Washington
Specs:
26g Bowfront
65w PC Light (8.5 Hrs/day)
DIY C02 (2 2L bottles) new bottle every 5-7 days. D.C. stays green using 5dkh solution. As soon as I get my Rex-ulator order I will be going pressurized (next week)
When I started dosing my 26g about 8 months ago, I was using this as a starting point:
_Dosing Regime's_ - The Planted Tank Forum
20~40gal
50%H20 change-weekly
+/-1/4Tsp-KN03 3x a week
+/-1/16Tsp-KH2P04 3x aweek
+/-1/16Tsp-K2S04 3x a week
+/-5ml or 1/16Tsp-Trace 3x a week
+/-1-2ml-Fe/Iron 3x a week
I know the EI thread here in this Forum, the extra K2S04 is not included in the dosing recommendations.
I understand that the KN03 and KH2P04 pretty much cover the pottasium requirement. Should I go ahead and stop dosing the K2S04?
I currently dose the following on this tank:
2ml-Fe/Iron 3x a week (Flourish Iron)
Excel 2ml daily
Growth is excellant, however the last month I have started seeing a small amount of BBA. Not sure what is causing this. My D.C. never changes from green even with the 5dkh solution.
89
5 dKH distilled or deionized water in the drop checker would be green at about 40 ppm of CO2. I don't think DIY CO2 will ever get that much into the water, so I think there is something wrong with how you are using the drop checker. It could be that the KH of the water is much lower than you think. It could be that you aren't using distilled or deionized water. But, BBA usually means either low concentration of CO2 or water circulation in the tank that is not adequate for keeping CO2 enriched water available to all corners of the tank.
nwfishinfool
Jun 22, 2007
45
62
Seattle Washington
I actually have two different solutions made up that I use in my DC. One is 4dkh and the other is 5dkh. I check the solutions each time I change the solutions in the DC. They are both made with deionized water. When I change the solutions, I clean the DC well, followed by a rinse with either the 4 or 5 dkh solution and add 3 drops of the Meth Blue. Is is a Red Sea DC.
When I use the 4dkh the DC getts pretty yellow, when I use the 5dkh it stays a nice green color. I don't let my yeast solutions run very long to try and keep the output as consistant as I can. The DC is on the opposite side of the aquarium than the reactor.
I am using a homemade in-tank reactor. 1 1/2" thinwall tube with the C02 entering mid way and a zoo med micropump pumping water into the top of the reactor. Appears to be desolving the C02 very well. I have a very small amount of micro-bubbles that push out the bottom of the reactor. I have the bottom plugged with fairly fine filter material.
Regarding the BBA, my original thought was it was a circulation issue also. I am running an XP3 wide open with a spraybar slightly rippling the water surface. The odd part is, the BBA is showing up mainly on the top plastic part of the in-tank heater and in a couple spots on the substrate. Both areas have enough circulation than you can see the BBA waving in the "wind".
Also, what are your thoughts on the K2S04? Not needed with my other ferts? Any chance the additional Potassium is causing the BBA?
Thanks Hoppy,
Mike
89
It certainly seems that you do have about 40 ppm of CO2 and good water circulation. I haven't read anything I can recall that suggests that potassium in any quantity leads to any kind of algae. As far as BBA on hard surfaces in the tank goes, when I get BBA it always hits those surfaces as bad as any other in the tank. The only other thing I can think of is routine weekly cleanings - doing those well is also good insurance agains algae attacks. With that I have shot my last arrow!
798
If you have BBA, you need to describe each aspect of the CO2 system, not just the data from one reading or a DC reading.
While they are useful, they have a long lag time and color reading is tough for many.
I think the water is your asrea should be fairly good as far as KH, so the pH meter would give you better responsive results more than likely.
Also, by the time you measure the CO2, after BBa is there, you may have corrected the issue.
BBA generally will not go away on it's own, however, you can stop new growth or add Excel and manual cleaning/trimming to get rid of the stuff that remains.
While manuy seem bedeviled and in disbelief with CO2 and BBA, it really is solely a CO2 issue, no matter how many folks claim it's something else, they generally have not looked at the their CO2 close enough if they believe this.
I've never once been able to induce BBA with anything else suggested.
Until that day, I'll stick with CO2.
I've also cured every BBA issue going back 15 years using nothing more than CO2.
I spent 3 years messing with BBA, Steve and I talked a lot and spent a long time figuring it out to be sure.
If you have BBA, you will believe anything if simply adding a little bit more CO2 did not seem to resolve things for you.
Some limited PO4, but that decreases photosynthesis, which in turn also limits CO2 uptake and thus demand.
So now you do not need to add CO2, you are now PO4 limited, not CO2 limited at that point.
This example is classic myth/pitfall of equating correlation to cause.
Getting good stable CO2 is 90-95% of this hobby if you use CO2 gas.
Never underestimate it and think you know it all when it comes to CO2.
Only a fool would do that.
I've been a fool a lot in the past on that one.
Now I know better and give CO2 the respect it demands.
nwfishinfool
Jun 22, 2007
45
62
Seattle Washington
Thanks for the inputs guys!
I should have my regulator from Rex in about a week so I won't need to battle the inconsistancy of yeast production any longer. Hopefully that will solve the issue.
The BBA is minimal at this point and I remove any I see during the weekly cleanings and spot with excel. Hopefully I can keep it under control until I get the pressurized system set up.
nwfishinfool
Jun 22, 2007
45
62
Seattle Washington
Oh Yeah,
Back to the K2S04, based on what I dose, should I stop adding additional K2S04? Tom/Hoppy - Is that part of your dosing regimes in your tanks or do I get enough with the KN03 and KH2P04?
Excel 2ml daily
89
I have never dosed K2SO4, and don't even have any. To the best of my knowledge there is enough potassium in potassium nitrate. But, I also have never heard of additional potassium causing problems.
aquabillpers
639
Tom Barr;22756 said:
While many seem bedeviled and in disbelief with CO2 and BBA, it really is solely a CO2 issue, no matter how many folks claim it's something else, they generally have not looked at the their CO2 close enough if they believe this.
At the risk of being a repetitious bore, I have to say again that there is something else besides low CO2 that causes BBA. I have soil based, non-CO2-injected tanks that do NOT have BBA. (Some do have other kinds of algae, though.)
I also have tanks that do have BBA. The only difference that I can see between the afflicted and not afflicted tanks is that the former might not have as good water circulation, because of my failure to thin out the plants enough, but there could be other variables.
Any thoughts?
Bill
89
Soil based, non-CO2 tanks presumably have low light intensity too. No aquatic algae does well with low light. Is that the reason why CO2 is not the issue with such tanks?
aquabillpers
639
I don't think so. For example, I have a hair algae problem in some tanks, and I have to wipe the (front) glass every now and then to remove the algae that grows there.
Thanks.
Bill
798
Algae grows in both CO2 and non CO2 tanks quite well and for the same reasons, however, it does tend to be less, the rate of growth, in non CO2 tanks vs CO2 enriched tanks.
Mostly due to higher light, but CO2 also helps algae to grow also.
Not enough plants, bad stability with CO2, lulls in NH4 stability/uptake, not cleaning up after you muck things up, clean the filters, trim etc.
The rates are slower, that's all.
Which is not bad.
Really bad algae issues occur in non CO2 planted tanks when:
Too much light
NH4 leaching from soil
Frequent water changes(adds pulses of high CO2)
Not enough plants.
And unlike the CO2 method, not doing water changes.
aquabillpers
639
I'm not sure what you mean by "low light" but I have a 2 wpg 20 long that is a veritable paradise for hair algae, probably cladophora. Other algaes thrive in it as well.
At one time the aquarium was essentially algae-free, but something happened, probably due to inadequate maintenance and an ammonia surge. It is a healthy tank and the Amano shrimp love it, but the required algae removal is a PITA and it will be taken down.
Bill
aquabillpers
639
Which is not bad.
Too much light
Not enough plants.
Is it possible, then, that increasing the CO2 to combat algae might actually make the outbreak worse, at least in the short run, since it takes a while for the plants to adjust to and make use of the additional CO2 while the algae react faster?
Bill
798
Bill
In the short run, I'd say yes.
JamesC
50
6
59
Kent, UK
Is it possible that KH could also have and effect in regard to BBA? I only say this as I've noticed a trend where people with a high KH seem to be more prone to BBA outbreaks than tanks with a low KH. I even noticed this myself with my tanks. When I ran high KH (>10 dKH) BBA was quite persistant and required high CO2 levels to control. Low KH (
798
I've rarely had issues with BBa in hard water tanks.
Moderate or soft water I've seen more.
BBA grows best in nature in softer waters, with about 10ppm of CO2.
Back to the topic:
If you have high NO3 in the tap, then adding K2SO4 can help in place of KNO3.
Adding K2SO4 will not hurt anything either way though.
nwfishinfool
Jun 22, 2007
45
62
Seattle Washington
Thanks Tom,
I think for now I will continue with my original dosing schedule, including the small amount of K2S04 I have been adding. Everything is growing well so I hate to mess with it.
I just got my C02 cyclinder today and the regulator should ship this week so I will have a stable source of C02 very soon. Hoping this will solve my minor BBA outbreak. I also changed the position of my filter outlet for a different flow pattern in the tank.
