Ada Aquasoil Amazonia Lowers Kh And Ph?
Discussion in 'Advanced Strategies and Fertilization' started by Cocoboitoy, Feb 12, 2018.
  1. Cocoboitoy
    Cocoboitoy New Member
    Feb 8, 2018
    11:55 AM
    Hi planted tank experts, I've read somewhere that ADA aquasoil lowers KH and pH of water. I was wondering if it's possible to use this as a media to lower my KH and PH? I'm thinking of putting some aquasoil in a media bag and place it in my canister. Will it work? Thanks.
    Sent from my iPhone using Tapatalk Pro
  2. Kyalgae
    Kyalgae Lifetime Members
    Aug 25, 2016
    347
    234
    12:55 PM
    Seems like an expensive way to lower the pH. I'd imagine you'd get a lot of aquasoil dust in your tank, and if you move it around a lot it will start to break up. I have never done this poersonally, but peat moss will lower the pH. If you add it to the filter bag, it will turn the water more tea coloured. I wonder if anyone here has actually tried it on this forum. I know there are different grades of peat moss, and you'd probably want a more coarse grade. https://www.pthorticulture.com/en/training-center/what-are-the-grades-of-peat-moss/
    Reading that you'd want the coarse chunk grade, or horticulture grade. Has anyone here tried this?
  3. Cocoboitoy
    Feb 8, 2018
    11:55 AM
    Thanks for the info. The thing is, I want the tank water to be clear, will Purigen fix it if I use peat moss?
  4. Kyalgae
    Aug 25, 2016
    347
    234
    12:55 PM
    http://www.seachem.com/support/forums/forum/general-discussion/1971-purigen-and-tannins
    http://www.seachem.com/support/forums/forum/general-discussion/21413-does-tannin-shorten-the-useful-life-of-seachem-purigen
    Apparently purigen will remove the tannins (that makes the water tea coloured) over time. Peat moss is pretty cheap, you could run a test without breaking the bank.
    Cocoboitoy likes this.
  5. AquaMatt
    AquaMatt New Member
    Mar 6, 2018
    9:55 AM
    I’ve tried it and it didn’t work at all for me. My ph stayed at 8.5 my ppm 150.
    Half oz in top filter, full oz in canister filter.
    I used the Fluval peatmoss pellets. 01D53865-1CBF-4EEE-ADE6-5E3B2FCC14DE.jpeg
