ADA Aquasky LED PAR Readings
Discussion in 'Lighting' started by thegasman, Nov 25, 2012.
  1. thegasman
    thegasman Subscriber
    Aug 25, 2012
    252
    9:18 PM
    I finally rented a PAR meter from Aquatouch today. I tested my 34 gallon 20" cube tank that is lit with two Marineland Planted Tank LED lights and have posted that data.
    I also tested my empty (not for long) ADA Mini-M with Aquasky LED light.
    The fixture is about 3" above where the water line will be. Directly under the fixture and about 3" from the bottom of the Mini-M tank, the PAR reading is 95.*
    At the front of the tank (about 3" from center of fixture), the PAR reading is 80.
    It looks like this fixture should provide fairly high light.*
  2. Tom Barr
    18,692
    712
    9:18 PM
    PAR should be measured across the entire sediment area.
    It's nice to also have a distance (at various cm's or inches) vs PAR in the center of the tank.
  3. thegasman
    Aug 25, 2012
    252
    9:18 PM
    Sorry for the lack of data. The readings that were provided at 3" off center are an average of many readings taken. The lowest readings in the extreme corners are 70 PAR and the highest reading in the center was 90 PAR. Again, these readings are at the front and back glass, about 3" from the center of the fixture on an ADA Mini-M.
  4. Marcel G
    Marcel G Banned
    Jun 5, 2012
    173
    17
    9:18 PM
    Finally, I have measured ADA Aquasky 361, Aquasky 451, and Aquasky 601 with PAR meter. So if someone's interested, you can look at my website, where there are the data with pictures: http://prirodni-akvarium.cz/index.php?id=mereni.
    PS: It's in Czech language, so please, use Google translate. Hopefully, I get it translated into English soon.
    #4 Marcel G, Jun 19, 2014
  5. Tom Barr
    18,692
    712
    9:18 PM
    Good data, it appears that as the fixtures get larger, the umol's become more even. This is true with T5 and PC lighting also.
    The 60cm 601 looks pretty good.
    the 602 would be interesting also.
  6. wintu
    wintu New Member
    May 15, 2012
    9:18 PM
    nice website and lot of good info
    zdravim do ceska !!
  7. DukeNJ
    DukeNJ Lifetime Charter Member
    Sep 18, 2009
    146
    9:18 PM
    Very nice. Love the way you test. Didn't see the AquaSky measurements though.
    Nice work.
