A new start - Fluval F90 - 129L (33G) - Iwagumi
Discussion in 'Journals' started by Coasters13, Jul 26, 2017.
  1. Dkoi
    Dkoi New Member
    Jul 1, 2017
    13
    10:02 PM
    Thanks ! I use the dimmer most of the time. Lights are 20 " from the substrate , so PAR is about 66. I have had every kind of algae, but is better now with stable c02 & EI dosing
    Love the Fluval LED lights !!
    Sent from my SM-G935W8 using Tapatalk
  2. Dkoi
    Dkoi New Member
    Jul 1, 2017
    13
    10:02 PM
    Also I forgot to mention. I didn't have a problem with the lights in the beginning because I planted my tank heavy from the start. I did not start fertilizers until the root tabs were depleted at the 3 month mark. That may be why you got a lot of algae. Your plants weren't using the fertilizer & with the high lighting , it's a recipe for an algae bloom. Now that my plants have good root system I have turned up the light intensity & use the EI dosing. I did get bba a month ago, but reducing the lights tends to make it go away pretty quick. Here's a " before & after "
  3. Coasters13
    Coasters13 Member
    Jun 29, 2017
    47
    29
    7:02 AM
    Day 10 :
    I did the second WC yesterday @day 9
    water column after WC
    NO3 10ppm
    PO4 0 ppm
    K > 40 ppm
    Mg 6 ppm
    Fe 0 ppm
    dosage :
    NO3 : nothing
    PO4 1ppm 3x/week
    Fe 0,2 ppm 3x/week
    K : nothing
    I have always NO3 in my aquarium but I add nothing
    I'll check if it's comes from RO water
    PO4 : I don't understand why it's still at 0 after 48h
    Fe : I don't understand why it's still at 0 after 48h
    K : high level coming from KH2PO4 and from K2CO3
    I have some questions :
    I have green algaes so I trun down my light from 8h to 6h and from 100% to 80%
    I have dennerle tropica 48w 4480 lumens for 125L or 33G
    But Eleocharis is dying
    what should I do ?
    increasing my light for more photosynthesis but I already have green algae
    increasing Fe ? how much ?
    increasing PO4 ? I add already 1ppm 3xWeek and still 0 after 48h
    Thank for your help !
  4. Dale Hazey
    Dale Hazey Junior Poster
    Feb 18, 2017
    165
    144
    6:02 AM
    I'm no expert but,
    don't be afraid of a little nutrient excess, that won't cause algae.
    reducing the photoperiod and intensity was a good idea
    NO3 shouldn't be coming from the R/O
    ADA soil rich in nutrients and some ammonia Probably why you have NO3. If you are bottoming out on phosphate and iron I would up the KH2PO4 and traces. I'm sure the hair grass will rebound, some of mine was browning and dieing like that, but most of it survived and spread, give it a haircut and it should spread faster horizontally
    #24 Dale Hazey, Aug 2, 2017
  5. Dale Hazey
    Feb 18, 2017
    165
    144
    6:02 AM
    Adjusting the lighting like you have done, and increasing the PO4 should help avoid too much GSA
    Rajkm is saying the substrate might be taking some of the nutrients, could be why you are seeing zero PO4 and Iron
    #25 Dale Hazey, Aug 2, 2017
    Coasters13 likes this.
  6. Coasters13
    Coasters13 Member
    Jun 29, 2017
    47
    29
    7:02 AM
    Hi all,
    here are the news of the second week (day 14)
    I did the third water change (75%)
    And I put my "old" fish from my previous tank (cardinalis and ramirezi)
    after water change and addition of GH+ my Water column was :
    NO3 : 5-10 ppm
    PO4 : still 0
    K : 20ppm
    Fe : 0.2 ppm (I did a mistake during last week and I had Fe @ 1ppm before WC)
    After addition of macro and micro my water column is :
    NO3 : 10ppm
    PO4 : 0.5ppm
    K : 25ppm
    Fe : 0.2 ppm
    conductivity : 300µs
    Daily dose :
    NO3 : 1ppm
    PO4 : 0.6ppm
    K : 3.4ppm (added via K2CO3)
    Fe : 0.05ppm
    easy carbo : standard dose
    CO2 : 20-30ppm
    GH : 5
    KH : 0
    pH : 5.7 - 6.2
    Green dust algae are under control but still there
    maybe the high level of Fe could induce this algae ?
    although I did a big water change, I keep my light low (7h @ 70%)
    here are the calculation of my PAR :
    @ front glass :
    @ back glass :
    So @ 100% intensity I'm between 60 and 80 PAR
    I'm now @70% intensity so I must be between 42 and 56 PAR during 7h
    do you think it's enough or should I increase my photoperiod up to 8h ?
    what do you think about intesity ? is it right ?
    DutchMuch and Dale Hazey like this.
  7. KeeperOfASilentWorld
    Aug 3, 2017
    57
    14
    7:02 AM
    Your tank looks great. Which site did you use for those estimate calculations?
  8. DutchMuch
    DutchMuch Junior Poster
    Mar 8, 2017
    1,033
    389
    6:02 AM
  9. KeeperOfASilentWorld
    Aug 3, 2017
    57
    14
    7:02 AM
    Thank you for sharing :) I personally found the estimates very accurate.
    Jason King likes this.
  10. Coasters13
    Coasters13 Member
    Jun 29, 2017
    47
    29
    7:02 AM
    BINGO !
    after some research I found the data on my light !!!
    between 30 and 40cm I have 77 and 54 PAR
    The calculation gave me 80 and 60 PAR so not so far
    very nice calculator
    DutchMuch and Jason King like this.
  11. Jason King
    Jason King barrreport.com
    Nov 20, 2011
    1,575
    361
    6:02 AM
    @Coasters13 thanks for the feedback on the Calculators, it's good to see that they are almost there, obviously we can't test all lighting on the market without donations or spending lots of money :) so a lot of the results are based on information like the dennerle datasheet.
    DutchMuch likes this.
  12. DutchMuch
    Mar 8, 2017
    1,033
    389
    6:02 AM
    If your taking light suggestions, Fluval line of lights some people have now and is pretty common im seeing such as Aquasky or something
  13. Jason King
    Nov 20, 2011
    1,575
    361
    6:02 AM
    Yes it would be a great feature to have results based on a brand, type of light rather than just say led etc as they are all different, again only way is for the manufacturer to provide that information, send us the lights to test or for Hobbiests to test, log and send us the results and then we can add that data similar to what we do now with the Nutrient Calculator and premixed branded ferts.
  14. DutchMuch
    Mar 8, 2017
    1,033
    389
    6:02 AM
    Sounds pretty darn sophisticated! can you ask them for a sponsorship or something in order to do that?
  15. Coasters13
    Coasters13 Member
    Jun 29, 2017
    47
    29
    7:02 AM
    Hi all,
    here are some news of my aquarium 3 weeks after the start up
    GSA are still there but under controle.
    I reduced my light, I'm now at 8h for 70% intensity (I have the Dennerle 48W 4480 lumens 90cm n°5556 - see table above)
    so my PAR is about 38 - 54
    Since my aquasoil is pumping my PO4 very fast I changed my Fert dosing (see my post here : )
    https://barrreport.com/threads/is-aquasoil-ada-amazonia-light-powder-pumping-po4.14444/
    I'm now adding EI daily dose
    NO3 : 3.4ppm/day
    PO4 : 0.6ppm/day
    K : 3.4ppm/day via K2CO3
    and I'm not adding Fe via trace because my Fe level is too high
    Fe was at 0.8ppm, after big WC it's now at 0.2 ppm
    I'll check the Fe and select the right dosing, may be half of the dose
    but it seems that eleocharis mini is not pumping my Fe too much
    I added Amano shrimps (5) to see if they are in nice place in my aquarium because my pH (6.0) is a little bit too low for them
    I'll add more if they don't die
    my Ramirezy is also building a nest ... may be for new babies soon ^^
    here are some pictures
    The last picture is Ramirezy nest ^^
    have a nice day
  16. DutchMuch
    Mar 8, 2017
    1,033
    389
    6:02 AM
    I feel like such a noob, had to look this up.
  17. Lovebug
    Lovebug Member
    Jun 25, 2017
    45
    63
    1:02 AM
    Looks like its turning into a nice carpet!
  18. Coasters13
    Coasters13 Member
    Jun 29, 2017
    47
    29
    7:02 AM
    BINGO !!!!! I found were my PO4 is going out !!!!
    it's not in the ADA amazonia light powder aquasoil as I though some weeks ago
    see me previous trial : https://barrreport.com/threads/is-aquasoil-ada-amazonia-light-powder-pumping-po4.14444/
    my PO4 is precipitated in my aquarium !
    this is why I always have PO4 = 0 ppm even with EI dosing
    here are the picture of the top of my aquarium and the PO4 is there !!!! (it's the bubles) :
    I took the bubles in a glass :
    I put it in a test kit for PO4 :
    and here are the results :
    !!!! I remind you that the water of my aquarium is PO4 = 0 !!!
    everything is in the bubles on the top of the water
    do you had such experiment ?
    I add in my aquarium :
    - MgSO4 and CaSO4 (for GH = 5)
    - K2CO3 (juste a few ppm as buffer KH = 0.15)
    - KNO3
    - KH2PO4
    - Element trace mix for Fe and traces
    I add only RO water and I do 50% water change every weeks
    please could you help me to find how I can put PO4 in the water column ?
    I ask me some questions if it's not link to the new ADA aquasoil because ADA removed PO4 from liquid fert
    now it's not step 1 - step 2 - step 3 etc any more
    it's a new line WITHOUT PO4 ......
    is it possible to grow plants without PO4 in the water column ?
    thanks for your help !
    Dale Hazey and snarkingturtle like this.
  19. Jason King
    Nov 20, 2011
    1,575
    361
    6:02 AM
    Just wondering if you get the same results/readings out of the tank?
    • Jar of your tank water and no substrate.
    • Jar of your tank water with some of the substrate.
    • Jar of just your ro water and nothing else
    • Etc.
    Dale Hazey likes this.
  20. Coasters13
    Coasters13 Member
    Jun 29, 2017
    47
    29
    7:02 AM
    Hi jason,
    I did a trial some weeks ago :
    my issue is :
    I put 1 ppm of PO4 in my tank, 5 minutes after I checked the PO4 in my tank and it was @ 1ppm (confirm with a standard made by myself) so the PO4 is in my tank at a good concentration : (liquid fert is ok and is not the issue)
    12 hours after adding 1ppm of PO4 in my tank, I checked the PO4 in my tank and it was @ 0 ppm !!! so the question was where was my PO4 ???
    what I did :
    I put ADA aquasoil with RO water, immediately checked the PO4 and it was @ 0ppm
    I put ADA aquasoil with a standard solution of PO4 1ppm, immediatelty checked the PO4 and it was @ ~0.5ppm (PO4 already pump by aquasoil)
    I put a standard solution of PO4 1ppm as standard, immediatelty checked the PO4 and it was @ 1ppm
    I waited 12hours (1 night) and checked the PO4 again
    I put ADA aquasoil with RO water - 12 hours after : No PO4
    I put ADA aquasoil with a standard solution of PO4 1ppm - 12 hours after : No PO4 !!!
    I put a standard solution of PO4 1ppm as standard - 12 hours after : 1ppm of PO4
    So the conclusion for me was : ADA aquasoil was pumping my PO4 and the PO4 was in the soil et available for roots plants
    BUT
    since some days I saw some bubles with some solid and precipitate on the top of my aquarium
    I stopped EI dosing and here is what I did in my tank :
    - day 1 : No liquid fert : no bubles
    - day 2 : addition of KNO3 only (NO3 = 3.4ppm) : no bubles
    - day 3 : addition of K2CO3 only (K = 3.4ppm) : no bubles
    - day 4 : addition of K2SO4 only (K = 3.4ppm) : no bubles
    - day 5 : addition of KH2PO4 (PO4 = 0.6 ppm) : BUBLES !!! (after a few hours)
    I took the bubles and checked the PO4 and bingo, it was the PO4
    at the same time, if I took the water of my tank without bubles, my PO4 is 0 ppm !!!
    conclusions :
    tank water without bubles : PO4 = 0
    tank water with bubles : PO4 > 8 ppm !!!
    the questions are why PO4 is precipitated ?
    1) PO4 reacts with ADA aquasoil and precipitates ?
    2) PO4 precipitates because my KH is too low (I add only RO water and just a few ppm of K2CO3 as a buffer) ?
    3) PO4 reacts with someting in my water column but what ?
    I will do some trials and keep you inform but my PO4 in my column water of my tank is always @ 0ppm
