I have been thinking, which can be dangerous, and it occurs to me that one could make an inexpensive aquarium light using a fresnel lens plus a Luxeon Rebel Endor configuration LED, which can produce about 500-700 lumens. This would have the LED mounted at the focal point of a short focus fresnel lens, so the light would exit the fixture as a 10 inch diameter, for example, beam. My crude calculation indicates that such a fixture might give 50 micromols of PAR, which, because the beam would be close to a parallel beam of light, would not lose much intensity at a two foot distance. Just two of these, side by side, would light a 10 gallon tank.
Needless to say, I haven't done any experimenting with this. One problem is that fresnel lenses of that size and short focal length are expensive, perhaps as much as $150 each. But, the quality of the lens would not have to be very high, so relatively cheap stamped plastic ones could be used. And, it is possible to make such lenses photographically too - a transparent sheet with black line circles spaced just right also acts as a diffraction fresnel lens. That could be very cheap.
Why wouldn't this work?
