Right off the bat I do not agree and have the data to support it on the LED, while this might seem true, the reality is poor spread of the LED lighting itself is the trade off, I use less light using T5's and can dim those as well, for about the same to 1/2 the cost and the colors are far better for planted tanks.
The ATI fixture ends up producing nicer growth, using less energy than any LED custom configuration I could come up with.
There's no way you get 10-15% the energy using the best LED's with a good T5 system.
I have a PAR meter and the plants themselves also do not lie.
PUR/Spectroradiometer meter would require that you know specifics about the individual species since each plant species has optima for different wavelengths. Most adapt quite well however. Aesthetics does not always equate to = more growth, which is the main metric used.
This will remain an unknown, I'm not even if it's all that useful outside a specific study on a specific plant.
No one is really going to fork out 3000-4000$ for such a meter and all the work involved to confirm the PUR, and that's just for one species and hopefully all your controls are decent.
It can be done, but really doubtful any hobbyist is gonna do it.
"I have found the use of a PAR Meter over rated by some."
I don't in light of the trades involved to go BEYOND that and into the PUR area, unless you have a better alternative, then why bother?
You will end up making it even MORE confusing.
PAR is used in most general plant growth studies in Biology for aquatic plants. They do not measur ePUR in virtually any studies I am aware of, arguing for PUR over PAR needs some experience and background to support. And I've not seen any from anyone in the hobby as of yet.
PAR is used, then from there, simple experience with different bulbs, bulb types.
Since aesthetics also plays a LARGE role, often larger than growth rates, this is the practical path most hobbyists will take, none I know of will take PUR.
With coral, studies can help with PUR, I'm afraid that you cannot confer that to plants however. Few study this issue with aquatic plants.
The example used with MH vs the 12 W LED is bias. The spread with the MH covers 2x2 ft, or 4sqft, the coverage for the 12 W LEd is not much more than the pot shown, about 1/10 or 10% of the same area.
If you only need to add light for a small area, LED's are good, if you need nice large even coverage, MH's or T5s are better.
There is no mention made in the article about this fact.
The comparison is not fair, it is bias. Common sense.
The article is good in many other ways however, that should not be overlooked.
