Tank: 75 gallon rimless - having this custom built so I have the option of getting it drilled.
Lighting: Tek or Aquaticlife 4 bulb t5ho - suggestions? Both seem to have individual reflectors for the bulbs. The Aquaticlife has built in timer but thats just something else to break without an easy way to replace it so I am leaning more towards the Tek.
Filtration: I currently have 2 Eheim 2073s. I'd really prefer something with lots of options with flow and very easy to maintain and not have a lot of equipment in the tank. I'm considering 2 options: keeping the 2 Eheims and have the tank drilled or a wet/dry.
I don't know alot about sumps and wet/dry filters and have never used either. I could use a little help with making a decision on which way to go with filtration and whether to get the tank drilled or not.
The wet/dry looks like a lot less work to clean than canisters with inline equipment. It also looks like I could get a lot more flow from it. My main concern with a wet/dry is the overflow and a possible flood from a power outage. I'm also not fond of a big overflow box inside the tank. So I'm kind of torn between these two options.
CO2: pressurized
Substrate: ADA aquasoil
CO2: pressurized
