This was when we first set up the tank it is a joint project between my girlfriend and I. Next day we planted it
We didn't know anything about aquariums or plants just planting plants with tons of light as suggested by our lfs. We ended up with 6 24" t5 HOs hair algae
of course. Only one small spot of cyano since we set up. My gf didn't believe fish could live without the bubbler in there but after some convincing I got her
to turn it off.
A short month after I stumbled upon plantedtank and found a co2 set up on craigslist for $100 including 5lb tank. Matheson MA957 and some needle valve.
None of its is great gear but it seems ok. At this point my gf was also dead set on not turning up the co2 more than 1bps because that's what the lfs does
and she thought it would gas the fish. The Vals in the back were slowly melting and we went for seachem flourish and iron as advised by the lfs but no luck.
At this point got an Eheim 2213 and aquaclear 50 running on the tank with about 2 bps the most my gf would allow haha. The stem plants grew much better
but our attempt at glosso and hair grass were failures. There was still rampant hair algae in the myrio which ended up choking and killing it. Also the gf
shoved some java moss in the nooks of the wood and we bought a pre covered log with marimo moss.
Recovered the log on the left with java moss and got a ista mixmax reactor and hydor inline heater to get some equipment out of the tank. The vals got so
ratty and covered with hair algae I ripped them out and replaced with "bacopa" on the right and "creeping Charlie" in the center with "Purple Cabomba" on
the far left and Rotala Wallichii . Im not sure what species these actually are as the lfs uses common names. We were still at 2bps and our new attempt at a
HC carpet slowly failed over a month or so.
Here it is currently. Running many many bps with the Ista on a Eheim 2217. Now we have two canisters and lily pipe set up and the tank seems much
cleaner. Only problem now is BBA and still some light brown dusting on the Ambulia, diatoms I think? I think this is due to the cheap co2 equipment maybe
but advice would be appreciated. Other then the tops the Ambulia seems wilted a little? We are dosing with the full aquavitro line according to rota.la. We
tried to get some Rotala Macandra ordered from the LFS but what they got was those two small stems in the front right.... pretty weak so hopefully Ill be
able to find some at the up coming GSAS auction =] Anyways thanks for reading my rant.
Jeff
