429 Dutch
Discussion in 'Aquascaping' started by Atb333atb, Dec 29, 2017.
  1. Atb333atb
    Atb333atb Junior Poster
    Apr 5, 2017
    100
    124
    8:30 PM
    Click pictures for details pls! sorry for my bad phone camera.
    I noticed some small spots of bbs on some plants so i added more co2. ph target now is 5,4 it was 5,6 until now. The problem is after i rise the co2 level some plants show me some deficit. What you think it is? I guess iron since i use DTPA maybe the new ph is too low for this kind of iron. Other micro? Have i activated some other limiting factor by the Liebig's law? i dont think is a macro since i have nutritive soil 100liters and my macro are: 15-20 no3, 2 po4, 6-8 mg, k over 45 via JBL test.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Prior to this i had some pale interveins, leaves which i thought it was Mg deficit. I add 30-40 mg epson salt at each water change because i have 1ppm Mg in my tap water.
    I am happy with the plant growt and look. Only pantanal is in poar sape and growth.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    What you think of this?
    #61 Atb333atb, Apr 29, 2018
  2. skija
    skija Lifetime Members
    Nov 16, 2015
    298
    52
    8:30 PM
    Usually melting is co2 issue ,but if you think you can master co2 good than it can be light deficiency ,but only if plants are growing in shade .
    I found out recently why my stauros are melting sometimes , NH4 , I gave the fish too much food 2 or 3 days and they didn't ate all the food so i had a lot of waste food on the bottom of my tank , 2 days later stauro was melting , so that means more NH4 , after 1 day BBA appears on some hardscape , ALL plants were growing slower.Water had a strange smell when i did the WC , something like sulfur
    I did 2 big water changes , cleaned the filter , trimmed the bad looking plants , all good in 2 days , its second time this is happening to me when I give fish too much food for a few days. I need to change fish food
    But if I look close to some pictures you posted i see some GSA which means too much light (or bad co2 circulation), considering you have 2 ppm of po4
    Trim your plants if they reached the surface , you might need better flow
  3. Atb333atb
    Apr 5, 2017
    100
    124
    8:30 PM
    I had dosed some ureea for a period of time. Not very much. Even with high value po4 you can get GSA if the N/P ratio is biger than 10. My soil absorb some of the po4 so i must dose separatly. Sometimes i forget or my no3 + nh4 gets high values. Meanwhile i set the target for my PH 5,3 and things are much better.
    Light is quite strong. I moved the lamp back to 25 cm beacause my walls gets dirty in less than a week.
  4. skija
    Nov 16, 2015
    298
    52
    8:30 PM
    Maybe stop dosing urea for a month or so and see the results ?
  5. Atb333atb
    Apr 5, 2017
    100
    124
    8:30 PM
    toads74, skija, Greggz and 3 others like this.
Tags:
