I need help with a 3 co2 connections on a DSR regulator build. The regulator is VWR Scientific model 55850-632. I planning to have 3 separate burkert 6011 solenoids with 3 Ideal needle valves to have each tank independently control. As for bubble counter, I will be using DSR Swagelok Tube Fitting.
I would assumed I will need a straight tube to connect from the regulator to a T, then another straight tube with another T, and then another straight tube off the 2nd T. At the end of each T, I will connect a solenoid and a needle vavle. I would love to use all Swagelok as parts but have no idea what parts to use.
Since the regulator is brass, I would like to stay with brass parts if possible.
I am not too familiar with all the little parts. I just know enough to get by. With this new build, it is little beyond my scope. Can someone point me in the right direction as what parts I will need to make this happen?
