  1. Dismiss Notice
24" T5 on 40B
Discussion in 'Lighting' started by slipfinger, Jul 6, 2017.
  1. slipfinger
    slipfinger Article Editor
    Jul 23, 2016
    355
    470
    9:00 AM
    I am embarking on my next project, which centres around 40B's 36" x 18" x 15".
    I'm currently sourcing lights, which will be T5's.
    I'd like to go with a hydroponics light but can only find 24" or 48".
    I'm guessing a double T5 will give me plenty of light considering the height of the 40's?
    Any thoughts or experience on using a double 24" light on this tank? Will it be enough light to grow most everything and will the shorten length cause issues?
  2. Dennis Singh
    Dennis Singh SynKing!
    May 5, 2013
    2,416
    639
    6:00 AM
    x4 will be high enough to grow anything
    odysea off ebay sells fixture that will fit perfectly, 39w each
    I use this fixture on my 40 breeder
    if you want to go 24", spread will lack on the sides and corners
  3. Greggz
    Greggz Lifetime Members
    Jan 6, 2016
    448
    574
    2:00 PM
    Agreed, the drop off is more than you would expect. And par also drops a bit as you get to the last 1/4 of the bulb on each side.
    When I had 48" lights over a 60" tank, I used to put crypts and other low light plants around the perimeter, as stems would struggle with the low par.
  4. slipfinger
    Jul 23, 2016
    355
    470
    9:00 AM
    Not what I wanted to hear, but figured this was the case before I even posted.
    Regarding # of bulbs, would a 36" dual bulb on 15" depth tank do the trick?
    I'm thinking 4 bulbs would give anything in the tank a severe sunburn?
    EDIT: On the other hand I was not considering the 18" width. 4 bulbs would probably be needed give a good spread?
    #4 slipfinger, Jul 6, 2017
  5. Dennis Singh
    May 5, 2013
    2,416
    639
    6:00 AM
    What are you trying to grow?
    4 bulbs you can always raise lighting extra costs
    dual bulb will grow a decent amount of things
  6. slipfinger
    Jul 23, 2016
    355
    470
    9:00 AM
    This will be a grow out, experimental tank, so there could be anything and everything in the tank at any given time.
    I do not want light to be a limiting factor, but I also don't want to break the bank..... I know, I want the best of both worlds.
    Ideally I want a 4 bulb with multiple banks, outside together and inside together, not sure if this is even an option. But finding a quad T5 at a descent price or a used one in descent condition is turning out to be a challenge, around my parts anyways.
