24/7 v solenoid v pH controller
George Farmer
135
45
Stamford, Lincs, UK
I've been tempted to invest in a pH controller in an attempt to keep CO2 levels stable at around 30ppm.
I've had good results with 24/7 injection before in my 33 gal. This time I'd like to save on CO2 refills (500g cylinder) and either go for a solenoid linked to the lights or a pH controller.
Any thoughts on 24/7 vs. solenoid vs. pH controller?
763
Forgo the pH controller and turn the CO2 on with a solenoid only during the day peroid.
That's what both Amano and myself have done and most every scaper in recent times does.
86
An advantage of a pH controller plus a solenoid, is that you can increase the CO2 bubble rate much higher, and arrive at the desired pH faster than if you use a lower bubble rate that itself controls the pH. I wouldn't spend the money for a controller to do that, but if I had a controller already I would add the solenoid to be able to do this.
Professor Myers
Aug 24, 2006
311
I'm pretty much in Agreement with Tom, and VaughnH. I'd add that a PH controller is only as accurate as the guy that calibrated it. (Ask me how I know) That may seem like a no brainer, but many times technology only provides the "Illusion" of control ! ;^) A solenoid on a timer is more than sufficient. A controller is just as likely to be another weak link in the chain. There's no substitute for conscientious maintenance. A PH Controller isn't an insurance policy. Found that out the hard way !!! ;^)
George Farmer
135
45
Stamford, Lincs, UK
Thanks for the feedback guys.
One quick question - is there any benefit to having the CO2 on for an hour or so before lighting so the desired CO2 levels reached at photoperiod start? Or do the plants take time to commence their photosynthesis and therefore don't require higher CO2 levels at the start?
763
Well, a little of both really, it would be best to make sure, thus add CO2 prior to the light coming on to get things really cranking right away.
If you have a larger tank or a long CO2 line, this might be a better solution, smaller tanks, probably will not make much difference if you have a good sized CO2 deliverly method etc.
rrguymon
Jul 23, 2005
52
68
ABQ NM
Yes it would be faster but it will also kill your fish if there is a malfunction. I have a pH controller and I only use it as a pH monitor and a fail safe to turn off the co2 if there is a manlfunction.
I set the bubble rate to drive the pH to my target and then set the controller to turn off the CO2 if the pH drops .3 or so below my target.
Is it worth the cash to by a controller for this? Probably not. I bought mine with the intent to control the pH and discovered it did not control the pH as consistantly as I wanted. The plus or minuse .2 in the controller was too much.
I love the real time ph reading on the controller however. If this one breaks I will definaty buy some time of real time pH monitor. If it only cost a few dollars more to add in a controller function I will get the controller just as back up.
Rick.
763
I tend to just add CO2 1/2 prior to the lights coming on, that adds plenty of gas during the photo peroid without the risk.
But yes, you can run a pH controller/solenoid adding CO2 at a higher rate for the day cycle also.
So adding CO2 to maintain a stable pH is really not the best of methods really I think. It works and all, but you get better results adding more and less fish stress at night when the lion's share of the 24 hours is low CO2 and relatively high O2.
Most folks run their light for 10-12 hours, so 12-14 are no CO2.
JinxXx0085
Jun 25, 2006
13
I didn't want to hijack the thread or anything.
I was wondering about this... running co2 without pH controller, won't it cause any pH crash or pH swings?
86
Shutting off the CO2 at night does cause a pH swing, but pH swings are a fact of life for plants in the wild, so it isn't harmful. A pH crash wont occur since the bubble rate is such that during the day the ppm of CO2 is stable and where you want it. At night it is shut off with the solenoid, so no crash then. At worst, the solenoid will fail and the pH will drop a little perhaps, due to lack of the plants using CO2 then. But, no crash. I had exactly that failure and wasn't even aware of it for some time later.
763
I've roasted 6 solenoids over the years FYI.
2 recently due to electrical surges. :mad:
