20 Gallon Long
Discussion in 'Journals' started by SpiritualEngr, Oct 4, 2018.
  1. SpiritualEngr
    SpiritualEngr New Member
    Aug 27, 2018
    11:55 AM
    Looking at around 5 weeks of growth here. Not too bad considering most of this came from tissue cultures and some LFS throwaways. The unbalanced lighting is have an obvious effect on the plant growth and has me thinking that I may want to move some things around. Thinking of making it more of a triangular layout with the tall side to the left and tapped to the right.
    Thinking of doing the following
    * moving the hygrophila corymbosa to the far left.
    * alternanthera reinckii to the center behind the drift
    * lobelia cardinalis to the left of the alternanthera reinckii
    * staurogyne repens in front of the drift / next to and in front of the hygrophila corymbosa
    * most like leave the crypt alone to see how it fills in
    Not sure if it would be better to move the alternanthera reinckii now or let it get taller first.
    Let's hear all those question, comments and concerns![​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Sent from my LG-H931 using Tapatalk
    rajkm and burr740 like this.
