Hy, im about to start a new high light tank and im concerned about the light. I got a 60x35x35 cm (24x14x14 in) 73 liter (~20 gal) Tank and a 2x55w PL light unit with built in reflectors. I will use pressured co2 and Ferts with EI method, and eheim 2322 + koralia nano for good flow. Sadly the lamps can only be turned on/off together, so basically i have to use 110 or 55 watts for ~20 gal. So its eighter 2.75 or 5.5 watt per gallon. I cant really decide, but since its my first high light tank i guess 55 watt should be enough. But on the other side im not sure if 2.75 w/g is enough for a thick HC carpet. I really dont want it to get leggy. I also would like a compact growth of: Alternanthera sessilis, Ludwigia glanduosa, Hemianthus micranthemoides, Riccia Fluitans, Rotala rotundifolia. Thanks for your help
Best regards Milan
Best regards Milan
