I am into 9 weeks of a dry start, everything is doing well (except my glosso) and I'm getting ready to flood it this weekend.
Week1:
Present:
Built a custom wet\dry sump using a 40 breeder. top cover seals the sock and bio chambers:
I will be using a Mag 18 fractioning pump for circulation and CO2 injection.
My question is, should I put the overflow box and pump returns on the same side of the tank (left), or would it be better to put the returns on the the opposite side (right) of the overflow? With ~1200 gallons\hr @5 ft head do you think this will be enough circulation for the tank, or should I throw a couple of Koralia 750's in there as well?
Also planning on dosing EI from the start, and blasting CO2 until I get some shrimp (how long to wait to add them) into the tank.
Dosing will be for about 180 gallons (tank + sump):
2 tsp KNO3 @3x week
1 tsp KH2PO4 @3x week
1 tsp trace @3x week
1 tsp iron chelate 13% @1x week (will need to check levels to see how much is consumed)
I will also be using RO water reconstituted with GH boost and baking soda to get around 3gH and 2-3kH.
Does this seem adequate for the tank?
I plan on 50% water changes 3x\week for the first 2-3 weeks and then 1\wk after that.
Does this seem about right?
Thanks in advance for any feedback!
Week1:
Present:
2 tsp KNO3 @3x week
