Hello everyone,
After just 4 months with this planted tank addiction I am already upgrading from a 72g bowfront to a 140g starphire aquarium.
I’ve been madly researching everything on this forum as well as other planted tank and reef sites. I’m impressed with the level of expertise and enthusiasm with which advice is provided to novices like me on this forum in particular. Therefore I am creating this build thread hoping to get some input from some of the planted tank gurus.
My ideas are mainly borrowed although there’s a few innovations of my own – I’m sure they’ve been tried though, just haven’t seen it online personally. So feel free to let me know what will work and more importantly what won’t!
Tank: 70x21x22 inside dimensions, ¾” starphire rimless – have preliminary quote from Miracles. Will be looking for feedback from members here before I firm up design and price.
Rear overflow: 24” Calfo toothless with BeanAnimal 3 silent standpipes – one full suction, one part, one emergency. Rear box 24x4x6. The back aquarium glass in this section will be ground down 1 ½” for overflow and this will set the water level in the tank.
Interior weir: Okay this is something I came up with… Size 24” x 1 7/8” x 21 ½”. It will have 1/8” x 2” slits across face starting 4” from aquarium bottom to allow for substrate. 1 7/8” depth of weir allows for insert of 2” filter foam.
Returns: 1” line from pump split into two 0.75” lines which enter near top beside overflow box. From there I will run them towards the front for 4” and then attach both to one full width spray bar about ½” below water level with most holes drilled for spray towards front at a downwards angle and a few angled up to cause some surface rippling.
Water circulation idea: Typically this style is used by reef keepers without the internal weir. The water comes out over the top and back in at the top. Since they require massive water movement they also build in closed loop systems so water is being pushed in all directions. Since it’s a planted tank and I won’t add these additional closed loops I need to create flow throughout tank. So the spraybar pushes water across the front, down and then across the bottom where water is being sucked in. Note that the height of the internal weir is such that if the bottom suction is blocked, water will flow over the top of this weir and into the overflow box without flooding.
The main reason for going through this complicated setup rather than sticking with canister filters is to allow for a sump in my basement. The sump will be 14’ below and I intend to build a continuous water change system and auto dosing system into the sump.
Sump: 125 gallon, long. I’ll buy the tank and build the rest myself using glass which I can cut and silicone in place. In addition to the usual features I’ll have a 30” planted section which can also serve as a nursery, hospital tank etc.
Filtration: Several filter foam inserts and wet/dry – sealed with tape thanks for the idea! I may add a canister filter to the sump as well since I have it.
Pump: Iwaki MD100RLT or Pan World 200PS. Leaning towards Pan World since reviews are great and so is price. I realize I’m comparing the biggest Iwaki to second biggest Pan World Pump but the flow charts seem to support this for my 14’ head setup.
CO2: Smith dual stage with AquaticLife PH Controller. Currently using Atomic CO2 diffuser although honestly I was using half the CO2 when I was putting it through the canister intake. May switch to reactor style and with output through ½” hose ending right in front of 1” pump intake on sump.
Auto Doser for Ferts: Not yet determined. Will be dosing daily using EI.
P.S. Any Canadians having problems getting potassium nitrate, check your local hydroponics shop – 1lb for $7.00. here in Mississauga.
Auto water changer: Simple drip run through FilterGuys activated charcoal dual stage filter to remove chloramines. Output will be at beginning of sump so filter will take care of the resulting minimal ammonia.
Overflow for sump: Here’s the best part for me. My sump overflow required for continuous drip system will run into a 30-40g quarantine tank. No more hauling buckets from my main to the quarantine daily for new rainbow fish additions. Quarantine tank will always be ready and be receiving approximately 75% water change with aged water from main every day. Will have overflow in quarantine tank as well to remove excess water – about 24g per day I think.
I realize if there’s a power outage (fairly rare here) that I will lose 5-7g from the system as the top layer of water from main and water from standpipes and return drain into sump and go out the sump overflow. By placing the sump overflow drain well above the return outflow I figure it would take 3 power outs in a row before the return line starts sucking air. I can always add automatic battery backup at a later date if this feature turns into a problem.
Lighting: Following the lead of a couple of rookie ATI users from this site, haha. Looking to use two 36” SunPower dimmable 6 light fixtures. Just trying to figure out how best to hide the cords. Based on Tom’s experience likely will hang it 12-14” over aquarium and am guessing 40-50% dimming if using 6 bulb fixtures.
Substrate: Confused by an overdose of information. Not sure whether to go with ADA or Eco. My water parameters out of tap are GH 8, KH 6, PH 7.8. I use the PH controller to bring PH down to 6.8 which puts the drop checker into the green. Plant types below.
Plants: Looking for somewhat low maintenance. Mainly going with Staurogyne, Blyxa, Anubias, ferns and perhaps a bit of Vals in the back as the rainbows seems to like that area of existing tank best as I trim and pull to keep the Vals from growing too densely. Sump will have Rotala Nanjenshan and java moss.
Livestock (present & future) – praecox,boesmani, turquoise, and millennium rainbows, bristlenose, otos, amanos, may try cherry shrimp too as I can use the sump as a nursersy to replenish.
Lid: Will be insetting a diy ¼” clear mesh screen inside lip of aquarium. Just attaching a few clear bumpers with silicone ¼” down inside lip and can place the screen frame right on these. Tired of dealing with the watery mess everytime I need to remove current glass lids and feel they’re blocking out a lot of light due to condensation.
Questions:
1. The big one – does the internal weir design and my water flow assumptions make sense?
2. Should I add a few slits in the front of the internal weir at water level to allow for a bit of surface skimming?
3. Other considerations for CO2 diffuser?
4. Is the ATI 6 bulb width okay for my 21” tank or do I need 8 bulb?
5. Substrate. Still confused with this – ADA or Eco?
6. Autodoser for ferts – any suggestions?
All comments welcome, Greg
Mockups of aquarium design ideas on post 14 and 24.
Questions:
