120 Gallon no CO2 tank
I have a nice rimless 120 Gallon 4x2x2 ft tank with a wet/dry built in over flow.
I've decided to do a larger scale version of my 60cm ADA.
I have a nice piece of wood suited.
The board is close to 2ft wide, and is 4ft long for a size reference.
Not sure if this piece will do what I'd ideally like, bit I will likely have to trim it down some.
Mostly plecos, but Serpa and dwarf Botia as well.
Hallen
Oct 8, 2010
130
The Netherlands (Gelderland)
That piece of wood looks like a small forest itself!
Very curious how this set-up will look. I have yet to decide for myself wether I like this style or not, the whole concept is quite interessting tho.
Me too, but............I do like it a lot and the look is very nice in person.
It's also extremely easy to care for and much more novel and different with how to plant, the level of horticulture etc........management.
In many ways, it's like Mangrove forest in concept.
Hallen
Oct 8, 2010
130
I like it alot on the picture aswell. The whole concep looks and design makes it perfect to keep serveral fish in a more natural habbitat.
Will you use floating mats/cups/etc normal for riparariums or will you let the plants attach naturally?
I'm a huge proponent of all things natural.
Sometimes, things like screws for slate for wood, or other things like glue etc might be used.
But rooting is generally natural, and any trays etc, will be made from modified driftwood pieces/scraps.
ShadowMac
1,043
13
Grand Forks, ND
I love the driftwood. Can't wait to see how this turns out.
Part of me wants to see an iwagumi esque layout with wood like that on a grassy hill with some stones.
Keep us updated on your progress
mr_ED
Dec 21, 2010
Philippines
sir,...very creative work. good job!
perfect gift for me during christmas hahahah joke. just registered in your site. nice to be here.
i've been hearing your names as well some of your writings here in our local site in manila,phils.
Actually the tank is being sold and I'm going to do a 48Lx 18T x 30" front to back depth instead.
I collect this wood where I live.
ShadowMac
1,043
13
Grand Forks, ND
Jealous of the hardscape materials you can find locally. Rocks and wood are hard to come by in my part of the country.
Is the key to non CO2 tanks primarily plant choice?
Well, now it's a CO2 enriched 48x30x18 tank:)
Things change and ideas are tossed.
You can see the duct tape around the lip of the sump.
A simple CO2 system, Victor reg, clippard in line check valve, burket solenoid, and Nupro valve with vernier micrometer handle. Feed into the intake of the needle wheel and into the return. Lots of sponge and bioballs. Clear PVC return.
I'll be getting a lot petite anubias in a few days and will tie them to the wood.
Neil Frank
56
tell us your latest thoughts on sumps vs no sumps.
How do you currently deal with air from the overflow... and its affect on CO2 loss (if any)? If you have already discussed this in another post, provide link. I have learned to like my sumps, but dont load it with lots of media. Instead a couple sheets of 2" coarse poret filter pad, and use the compartments with light over the glass lid for storing extra plants. Since CO2 is heavier air (O2 & N2), i dont worry as much about sealing sump with tape to prevent lose of CO2.
Latest? I like them? Is that good enough? hehe
Well, they do maintain about 1-2ppm higher of O2 throughout the entire 24 hour cycle vs even the higher cansiter filter flow rates and over sized systems, and at about 1/2 the required flow rates.....so 12000 GPH filter with 2 large Ocean clears is less able to maintain higher and more stbailty O2 and handle the fish load as say a 600gph wet/dry.
Ever try and clean a OC filter? PITA if they are under the cab, the Ehiem or Rena are oaky..........but the larger the canister filter, the bigger PITA they are.
I have some 2260's at client's, I hate them.
The wet/drys are just a lot easier to clean and deal with.
If the overflow sucks some air, so what?
It just ends up in the sealed wet/dry section, just enters into the solution as a dissolved gas, same for the degassed CO2, the chamber simply acts like a gaint CO2 reactors, some folks inject it in to the wet/dry chamber for that matter.
As long as that part is sealed, then the open end of the sump is fine, since there's no turbulance in that section, it can be open, just ike the top of the aquarium is. You just avoid tubulance there, movement is good.......just not breakign the water's surface. In the we/dry section, it does not matter since there is nowhere else for the gas to go other than into dissolved form.
George Booth, Myself and Steve Dixon all came to this same conclusion about 13 years ago or so now. We used pH to see if there was a difference and where it was. By reduction of the spill height for the prefilter overflow(most folks all do this these days) and sealing up that wet/dry section, the pH is rock steady for both cases, thus one may conclude with those modifications, there's no CO2 loss and the O2 is still increased higher than a canister since O2 and CO2 act independently and you are adding air, which is 21% O2 so the tough to dissolve O2 has a good place to interface with the water.
You can store extra plants, but I have buckets outside for that if I have any. I compost or sell them asap.
You'd have to search long and hard to find that APD post from STeve George and myself, we did agree 100% on that, all 3 of us.
The good old days.
They fill up with shrimp, otherwise, works like charm.
A small shrimp fluval net works dandy, has the extension, good for nabbing fry also.
