120 Gal Dutchy Freestyle - Now with 50% more Dutch!
Discussion in 'Journals' started by burr740, Jan 10, 2017.
  1. Sepp0207
    Sepp0207 New Member
    Aug 20, 2017
    19
    9:10 AM
    Hello burr,
    do you still have Pantanal in one of your tanks? How ist it doing? And did you test Ammannia/Nesae in one of your tanks?
    Greetings
    Sebastian
    maciek_L likes this.
  2. Pyae Sone Maung
    Pyae Sone Maung New Member
    Apr 19, 2018
    2:40 PM
    Hi Barr,
    Finally I found out that where should I start with my new tank. Please kindly allow me to copy some idea of yours.
    Cheers!
    #802 Pyae Sone Maung, May 5, 2018
  3. jbvamos
    jbvamos New Member
    Mar 26, 2018
    7
    4:10 AM
    time to trim, I need some more plants!
  4. burr740
    burr740 Micros Spiller
    Staff Member Moderator
    Feb 16, 2015
    1,398
    1,296
    3:10 AM
    For anyone not following on TPT, a couple of months ago this tank sprung a leak! The bottom seal blew out
    Here it is in progress
    [​IMG]
    Long story short, I would up going with a new 75 gallon in its place. Three days later it was up and running. I put the plants back in just like they came out
    About a week later
    [​IMG]
    Been a few iterations since then, starting to get a feel for the new layout
    [​IMG]
    [​IMG]
    Here's the latest. Think this is the basic layout Im going with as far as species and where they're at. Gotta work on shaping the groups, several things need to fatten up, etc etc
    [​IMG]
    Honestly Im tickled pink to be working with a smaller tank. Its so much easier to reach everything.
    Will start a new journal here pretty soon...
  5. Bishop
    Bishop Member
    Sep 17, 2017
    73
    70
    9:10 PM
    Shame about the leak, such a nightmare.
    Looks good though. Buce on the moss wall was a nice touch.
  6. burr740
    Feb 16, 2015
    1,398
    1,296
    3:10 AM
    Never had much luck with A gracillis but I havent tried it in a couple of years. Actually have some A crassicaulis coming from Vin should be here in a couple of days. We'll see how that goes
    Pantanal does fine for the most part. It likes high everything. Current ones in the farm tank
    [​IMG]
    [​IMG]
    Be my guest! :)
    You know where to find me! :) :)
    fanatic, Greggz and Tim Harrison like this.
  7. burr740
    Feb 16, 2015
    1,398
    1,296
    3:10 AM
    Thanks. Turns out it was blessing in disguise because Im loving the smaller tank
    Buces are probably going back whenever I get the "horizon" mapped out. They just stick in place, very easy to move/remove
    msb likes this.
  8. msb
    msb Junior Poster
    Feb 16, 2013
    78
    179
    8:10 AM
    Hey Burr,
    The 75 looks great already. I like the moss walls and was thinking about using something like that for my other tanks with annoying backgrounds. Sometimes Ill google "nbat aquarium" and look for ideas. On some of them you will see lobelia or maybe anubias planted somehow rite on the walls :eek:. Is that how you had some buce ? I didnt catch that. Also, I know you have some of your tanks with blackened out sides/back. Do you use paint to do that or some kind of cover ?
  9. geektom
    geektom Junior Poster
    Dec 16, 2012
    351
    326
    8:10 AM
    wow- scary about the leak, but the new tank looks fantastic!
  10. Pyae Sone Maung
    Apr 19, 2018
    2:40 PM
    Dear Bro,
    I have a few questions regarding about the filtration and circulation. My tank is 120cmx45x45 - 250L and I am trying to use 2 separate canisters like you.
    What is your design of water flow of this tank? If possible can u sketch some draft?
    What I have found in the internet is attached for 2 separate canisters. Can it ok?
    Thanks.
  11. burr740
    Feb 16, 2015
    1,398
    1,296
    3:10 AM
    That diagram is a good way to do it if your plant arrangement can take the current at it's strong points. For example if you have a tall group of delicate stems in the back left it may be disruptive
    Mine is different because the tall curtain plants in the front corners would get blown over too much.
    [​IMG]
    CO2 is connected to the right hand filter. It has the strongest gph. Aimed about the center of the front glass where it sorta disperses all around in the lower area. The left filter is also strong but I have it turned down a good bit. Its aimed at the surface going straight across the back, primarily to provide good surface agitation. Then it blows on over to the right and goes down the wall over there. For the most part the left side flow passes over and above the general direction of the right side flow, because the right side is aimed down.
    There is a some intersection with the two flows, which is generally to be avoided, but if the flow is too strong to begin with having them intersect can be a way of reducing velocity (plants arent blown around as much) as long as the intersecting flows do not create dead spots.
    So you'll just have to adapt the flow pattern according to the plant layout. Main thing is to have both filters complimenting each other in the same general direction so there are no dead spots
  12. Pyae Sone Maung
    Apr 19, 2018
    2:40 PM
    Noted with thanks bro. Very appreciated.
  13. AgMa
    AgMa Junior Poster
    May 30, 2016
    8:10 AM
    Hey burr,
    Could you please post your par readings?
    If I recall, must be about 120 at sub?
  14. burr740
    Feb 16, 2015
    1,398
    1,296
    3:10 AM
    The new 75 is around 100 at the sub. Only running 4 bulbs with a heavy red and heavy blue in the mix.
    Pyae Sone Maung and AgMa like this.
  15. AgMa
    AgMa Junior Poster
    May 30, 2016
    8:10 AM
    I noticed you don't dose any cl at all.
    Why? I think it's also important.
  16. burr740
    Feb 16, 2015
    1,398
    1,296
    3:10 AM
    Tap has ~9 ppm
    How much do you think is good?
  17. AgMa
    AgMa Junior Poster
    May 30, 2016
    8:10 AM
    I don't know how much cl is needed.
    I thought you were using 100% ro.
    #817 AgMa, Sep 3, 2018
  18. burr740
    Feb 16, 2015
    1,398
    1,296
    3:10 AM
    All tap! :)
  19. Pyae Sone Maung
    Apr 19, 2018
    2:40 PM
    Hi Burr,
    Can you name that 4 bulbs u used and arrangement?
    For 120-45-45 cm tank, 4 bulbs are enough? How many cm should rise the tubes from water surface since the soil is 6 cm.
    Thanks.
    Sent from my ONEPLUS A6000 using Tapatalk
  20. burr740
    Feb 16, 2015
    1,398
    1,296
    3:10 AM
    4 bulbs will be plenty. How high above the tank depends on whether it has a single reflector for all bulbs or individual reflectors for each one. The latter is much more powerful.
    With a single reflector you could position it anywhere from 6" and lower. With individual reflectors somewhere around 10-15" above the tank. That's just generally speaking, the type of bulbs also plays a role in how bright it is
    Color wise for four bulbs I like one very warm, a strong red, a strong blue, and then a 6500K or a pink flora type
    Current combo is 3000K, Powerveg 633, 420 actinic, Wavepoint UG
