Hi, it's been a while since the last time I posted but I keep reading hehe...
Ok, my tank has been running for almost 5 months now and many has been improved except for several species aquatic plants that won't grow no matter what way I tried to change the system, are Ludwigia arcuata and Hemianthus micranthemoides, strange...
Ok, here's my tank's specifications :
Water parameter :
Flora :
Fauna :
May 02, 2011.
First day setup, tank temp was around 28-29C and using 4X21watt T5NO. The left background plant was Rotala nanjenshan, no Ludwigia arcuata yet.
June 16, 2011.
All plants were growing fine and just adding downoi,
HM here was growing too, look like HC was spreading but the leaves were small and rather black and the root was somewhat looked floating between substrate rather than grow deep inside the substrate.
Lower leaves of downoi was rotting and falling off.
Algae was very hard to found. Everything nice and clean except some major issues with certain plants above.
July 28, 2011.
Here, Rotala nanjenshan was replaced by Ludwigia arcuata for I don't like the nanjenshan, sorry.
HM was apparently rot at lower stem and leaves after the first prunning I found out that most of their stem was floating and almost had no root and after 1 week of trimming or so, the remaining HM was died completely too.
HC was melted too and wasted away, I found the dead leaves stuck in my intake strainer everyday but the pictures above was taken right after replanted freshly.
The leaves of Downoi look like shrinking from day to day.
About 2 weeks later from this date, I bought myself a chiller unit and set the temp to 24-26C but also changing the light to T5HO 4x39watt at the same time (extremely plenty of light? I want to know if the HM and arcuata which rot at its lower stem was due to not enough light or something else, CO2? But...again but...I quite didn't think so). I also increased the CO2 here.
September 04, 2011.
I kept replanting new HM but history kept repeating itself.
Here, Ludwigia arcuata also have similarity history to HM, after it reached surface and be trimmed and replanted, 50% of them will rot in a week especially the upper trimmed stem part not the lower part.
The algae started to showed, BBA, cladophora and GSA besides BGA that occured from about 1 month after the first setup day at front of the glass below the substrate until this right moment but hardly reached above substrate surface, I always had BGA each time I used ADA Aquasoil no matter how hard I adjusted the flow and added a lot of nitrate. So action was taken, spot excel treatment and reduced 1x39watt to 3x39watt although the 1x39watt was turned on for 4 hours/day only. Now I'm using 3x39watt for 9 hours/day look stable enough with very minimum of algae.
But HC from here was seem to started grow nicely and spreading.
Couples stem of downoi was replaced to new one because they are stunting since the last time.
September 21, 2011
The left part of HM was replaced by Micranthemum umbrosum.
HC kept growing nicer and spreading bit by bit although very slowly, could it due to better tank temp since I added a chiller?
Newly planted Downoi was also started to grow bigger but the old one was seem to still stunted, hard to recover. Chiller effect?
The light was still the same 3x39watt 9hours/days.
The leaves of Rotala sp. green here turned out to be smaller not like before, what's wrong?
Algae was under controlled once again since last time excel battle.
Oh yes, I also had my tank water tested at lab at the day of my routine 70% WC weekly and apparently the seiryu stone is raising both the kH and gH over time. My water source has a pH, kH and gH of 7.1, 1-2 and 1-2 after I let it sat for 48 hours and my tank water tested result has the pH, kH and gH of 7.7, 5 and 9 at the end of the week after I let it sat for 48 hours too. If I read from the kH/pH/CO2 table, I have around 100+ppm of CO2. Mostly right after the CO2 is off at night, the pH will reach around 5.9-6.1 and the next morning before the CO2 is on again, the pH is around 6.8-6.9. Drop checker is deep yellow 3-4 hours after the CO2 starts and I have tried to placed several different spot and the result was quite the same.
In case you wonder what kind of the CO2 reactor I'm using :
Water is feed in the side hole from output of canister filter and then being forced to spin the valve and CO2 at the same time through the way down of that reactor chamber, spinning to find its way back to tank from bottom. The tile from the pictures above is 40x40cm. My CO2 rate is high enough that the CO2 gas accumulated at the top of that reactor as much as the two fan valve like pictures above. Please don't tell me that I have CO2 defeciency, still...
Sera is also make this kind of reactor
http://www.sera.de/en/products/tech...omponenten/sera-flore-co2-active-reactor.html
After I replace the the T5NO to T5HO, stem plant grow more bushier and the HC and Downoi grow at last but at the same time I also add the chiller so I don't know if the light or chiller that make they grow but again the HM and arcuata still fail to grow.
My dosing regime is like this :
KNO3 : 30ppm.
KH2PO4 : 3ppm.
K2SO4 : 30ppm.
CSM+B : 0.5ppm.
Seachem Flourish : 0.25ppm.
At the end of the week before conduct water change, I had my tank water to be tested on lab and the result was :
Colour : 25 ppmPt-Co
Turbidity : 1.25 NTU
TDS : 307 ppm
Organic matter : 5 ppm
Bicarbonate : 170.8 ppm
Total hardness : 170 ppm
Calcium : 56 ppm
Magnesium : 7.2 ppm
Chloride : 35.5 ppm
Chlorine : --
Iron : 0.3 ppm
Silica : --
Manganese : 0.0 ppm
Nitrite : 0.10 ppm
Nitrate : 5.0 ppm
Sulphate : 19.1 ppm
Unfortunately there is no Phosphate and Potassium reading, could it be that my hard water lead to arcuata failed growth?
Any kind of help and advice will be appreciated before and thank you very much for reading the so long thread.
- Tank size : 90x45x45cm.
- Fertilization : KNO3, KH2PO4, K2SO4, CSM+B and Seachem Flourish.
- Lighting : 3x39watt T5HO (too much light? I know, I know...but please read on).
- CO2 : Pressurized @6, 7 or maybe 8-9 Bps via reactor.
- Substrate system : ADA Amazonia I, Bacter 100, Clear Super, Tourmaline BC, Tetra Initial Sticks and WonderGro Root+ Tab.
- Filtration : JBL e1500 (1500L/H) and Eheim Pro3 2073 (1050L/H).
- Chiller : Resun CL-450.
- Hardscape : Seiryu stones.
Water parameter :
- pH : 6.0-6.8.
- kH : 4-6.
- gH : 4-9.
- Temp : 24-26C.
Flora :
- Hemianthus callitrichoides "cuba".
- Pogostemon helferi.
- Staurogyne sp.
- Blyxa japonica.
- Rotala sp. green.
- Ludwigia brevipes
- Hemianthus micranthemoides.
- Micranthemum umbrosum.
- Ludwigia arcuata.
Fauna :
- 40+ Paracheirodon simulans.
- 11 Otocinclus affinis.
- 20+ Caridina multidentata.
May 02, 2011.
June 16, 2011.
July 28, 2011.
September 04, 2011.
September 21, 2011
KNO3 : 30ppm.
KH2PO4 : 3ppm.
K2SO4 : 30ppm.
CSM+B : 0.5ppm.
TDS : 307 ppm
Calcium : 56 ppm
Magnesium : 7.2 ppm
Chloride : 35.5 ppm
Chlorine : --
Iron : 0.3 ppm
Silica : --
Manganese : 0.0 ppm
Nitrite : 0.10 ppm
Nitrate : 5.0 ppm
Sulphate : 19.1 ppm
