Re: Hydro Culture HPS Lamps
The problem with plant-bulbs is that nothing is added, just removed. To get more blue and red they filter out yellow-green. Energy loss. Nothing gained but uglier light.
You can calculate how much of the energy you put into the bulb is converted to ordinary human light, lumens. This gives you an efficiency how well the bulb produces photons in the human visible range. Together with the bulbs spectral distribution and a photosynhtesis action spectrum you can then calculate how many photons from the bulb that do good to plants. You have then calculated the Photosynthetic Usable Radiation efficiency. PUR-efficiency.
Sylvania GroLux has a PUR-efficiency of around 0.5 microE/Joule, compared to for example Philips Aquarelle (TLD89) with a value around 0.8 microE/Joule. I have calculated values for a couple of bulbs:
http://www.defblog.se/permalink/1402.html
Another take on this is that some bulbs only loses about 10% of its initial output intensity, GroLux/plant-bulbs are not included. But tri-phosphors like Triton, Aquastar, Aquarelle are.
All this is of no special importance when it comes to getting a nice planted tank especially not if you can afford the extra electricity and bulb-cost. With EI and good CO2-levels you will not find the light of any significance at all because you will manage to grow everything rather fast with surprisingly low light intensities.
But if you want to grow a plant faster than anyone else in some sort of growth-rate-competetion, PUR-efficiency would come into play. If you have an action spectrum for one specific plant I can tell you which bulb will grow that plant faster than any other bulb.
