When using metracide 14 as an excel replacement you do NOT add the "activator" to the bottle do you? That is for sterilizing purposes only, correct? It says it would turn the chemical green, which I know excel is not...
over_stocked;47338 said:When using metracide 14 as an excel replacement you do NOT add the "activator" to the bottle do you? That is for sterilizing purposes only, correct? It says it would turn the chemical green, which I know excel is not...
abcemorse;47485 said:What kind of dosing do you use with that, in terms of ml/gal? I use some excel, not a whole bunch, but am interested in this, it seems substatially cheaper....
I use metricide 14 at 100% strength. I bought it here, which seems to be the cheapest for 1 gallon shipped.
Biollante;47941 said:Hi,
What are you using 25ml of Excel a day on?
