I'm in week 2 of a new planted tank setup, and I'm in the process of coming to understand the flow patterns of my tank, getting the CO2 dialed in, etc. I've been gradually tweaking the CO2 levels up bit by bit, keeping an eye on the tank inhabitants as I go.
I've noticed that of late the Otos (of which there are about 15 now) have been tending to hang out in the back left corner of the tank, which is also where there happens to be the least amount of flow. Not all of them stay there; you see a couple out and about in other areas. But they mostly hang out there.
They don't seem unhappy per se - they keep active, and they're not gasping at the surface or anything. But them hanging out in that limited area does make me wonder if CO2 levels are so high that that corner of the tank is the only area where they can remain in their comfort zone.
Does that sound plausible? Or is it usually more obvious when CO2 levels are too high? Does anyone have any thoughts, general or specific, about how one develops a "feel" for this kind of thing?
[FWIW, the tank is 77 gallons, and the bubble count is just under 6bps. CO2 is being distributed by an ADA pollen glass.]
