Response time of your CO2 reactors
PeterGwee
126
Hi Folks, would like to find out how fast does your current CO2 setup return to optimal CO2 level (30ppm) from ambient level (3-4ppm). Tom's setup does that within an hour or so...does anyone have that kind of response time as well? :D
Regards
Peter Gwee
jippalbert
Jan 30, 2005
17
Philadelphia
Re: Response time of your CO2 reactors
What is your bubble rate that you can achieve in 1 hour.
I currently give it 2 hours
my co2 and reactor come on at 8am and the lights at 10am.
JA
PeterGwee
126
jippalbert, I'm currently testing it (2"x12" external reactor driven by a maxi-jet 900 (225gph) and uses it to "on"/"off" the CO2 instead of a solenoid) and haven't got the results yet...
Tom's setup is hooked up with his light timer so I guess the CO2 comes on with the light. He gets a response time of an hour or so from ambient levels and maintains it throughout the day (~30ppm).
Are you able to hit 30ppm (max) with your particular bubble rate and maintain it throughout the day? A 0.0-0.2 pH difference should be good enough I guess but you should hit max CO2 level within an hour as the plants are still half-awake.. :D after the lights come on.
Regards
Peter Gwee
