Not something I've seen too often in planted aquariums but I'm hoping a few people with experience will just give me their views and opinions on the system.
I think this system would suit me just right having the filtration built into the end of the display and allow me to access things with ease e.g. filter foam is quickly and easily removed for a rinse through, I'd also not have the pipes to clean through quite the same amongst many other things I would in a conventional external filter. I can also hide a lot of the things away like dosing pipes, ATO, heater etc.
Water is intended to sit somewhere around 12-20mm below the rim depending if I use a jumpguard or not.
-In the first section (weir) it is intended that water is drawn through the top so it will hopefully remove any surface scum, water would then go through some filter foam supported on egg crate to remove any debris.
-Next would be an under baffle and over baffle leading to the second chamber which water would flow down and mainly be bio balls for biological filtration but would also allow me to add things like Purigen or activated carbon should I choose all supported again on egg crate.
-Again there would be an under baffle and over baffle leading to the return section where I would locate the return pump, heater, ATO, dosing pipes and CO2.
The return pump will be adjustable so give me some control on flow passing through the system and I also plan to give an RFG Random Flow Generator a go to see quite how that works for getting flow around the tank.
There are some drawing which are not finalised; the main changes being the weir comb will start with a solid piece (not a large space), the weir comb will also be turned into slots so still the same height but with a 5-8mm capping piece over the top, ledges adding in the first section and I think that's about it.
Experienced views welcome to give me some input please.
