Hope this isn't the wrong forum for this question. I may be able to invest in some serious CO2 equipment. Gas canister, regulator, etc.
I'm in Canada, not a lot of choices, and some out of stock where there are sources. Having struggled with DIY cheap needle valves that never hold a setting reliably, what I'd like is a very reliable, accurate needle valve and regulator set up and some info on using a pH controller with them.
Some names of good quality brands and sources for same would be much appreciated.
I'd also like to know if it is realistic to split the feed for more than one tank? I am not very familiar with this type of equipment, so if that's not practical, just tell me.
