I'm looking at a set of Tunze nanostream pumps. I've got a 60x18" footprint tank and was thinking 1 Tunze nanostream 6055 or 6095 in each corner for a gyre effect and to allow for reversing flow or both on for some detritus clean out. The 6055 should be around 1500gph and should reach to the end of the tank. The 6095 is ~2500 but has a much wider flow and supposed doesn't reach much more than 3 feet so I'm not sure if it can set up the gyre I'm looking for. I've got two 6045s on it now but I'm hoping for more than just on/off and one of them seems noticeably weaker than the other but that may just need a good vinegar soak or impeller replacement. Either way I'm looking for a little more kick.
I considered the vortechs but generally do not really think that's where I want to go with this tank. The likelihood of them getting bumped on the particular tank is too great.
S
S
