Does glutaraldehyde really provide a carbon source for plants? Or does it work by killing the biofilm on plants which allows easier access to CO2?
- I read an article that stated that O2 levels are the same with or without adding glutaraldehyde. If it's a carbon source, then the rate of photosynthesis (by all photosynthesizing organisms, including algae) should be higher resulting in higher concentrations of O2. Further, higher concentrations should result in linear growth, but growth is nonlinear. This suggests that the increase in growth is due to other means.
Further evidence:
I've also observed that adding melaleuca oil (from API's Melafix) also increased growth at about the same rate as glut. Melaleuca oil (from the Tea Tree, Melaleuca alternifolia), is an antimicrobial chemical. Like glutaraldehyde, increasing the concentration does not result in increased rate of growth. If melaleuca inhibits the biofilm, then it allows the plants easier access to CO2 due to reducing competition for a very limited nutrient.
If true, then compounds that have antimicrobial effects, such as nutmeg oil, should also improve growth in submerged aquatic plants. And if glutaraldehyde isn't a carbon source, and works only by inhibiting and killing the biofilm on plants, then overdosing does more harm than good due to its biocidal effects.
Tom mentioned using C12 isotopes to track the carbon from glutaraldehyde. What were the results? This would prove or disprove this entire argument.
Further evidence:
