I wanted to double check what I feel I've read after doing some searching. I am new to dry ferts and want to make sure I don't mix anything that shouldn't be mixed, as well as check about premixing them with tank water / tap water for a drip system or such. Here is what I have:
Potassium Nitrate - KNO3
Monopotassium Phosphate - KH2PO4
Potassium Sulfate - K2SO4
Calcium Sulfate / Gypsum - CaSO4
Magnesium Sulfate / Epsom Salt - MgSO4
Ferrous Gluconate / Iron(II) Gluconate - C12H24FeO14
Plantex CSM+B
Seachem Prime / Safe
I believe it's best to wait a day after a water change when using a conditioner that detoxifies metals, such as Seachem's Prime / Safe, though many say it doesn't matter much as it can only bind a little bit of metals compared to what's being dosed. I figured I'd typically just not dose that day, but that means the water will have much less nutrients in it than normal that day rather than keeping it at a more steady level, so maybe I'll dose anyway...?
So what can be stored together dry for quick addition (once happy with ratios)? Sounds like iron should stay separate / with trace to avoid cloudiness? So can the macros and gh boost all be mixed together if desired? Can I mix the iron in w/ the CSM for extra iron?
What about in solution? If I wanted to set up a drip system or pump can I make a months worth and have all macros and gh boost together, and a separate one for trace / iron?
Will they all last that long without precipitating out of solution or causing any adverse reactions? I believe I read to add some excel (20 mls per 500 mls) to the trace to help it last out of the fridge without developing mold or clogging the lines.
I also figured I could just mix this with some tank water I grab out rather than having to dose tap water with Safe and then wait 48 hours before mixing with ferts, though if they last in solution a month or more that wouldn't be too much of a problem.
Thanks for the help on this new adventure!
Plantex CSM+B
