Hello all!
I have a 75G tank.
I am starting to win the battle against BBA now that I have a firmer grasp on CO2 and I'm also trying to fill out the tank with plant mass to aid in this fight.
I dose EI
I have a PAR of 125 at the substrate in areas that are not shaded, and the light is very even.
Lights run for 8 hours per day.
I have CO2 injected from a reactor which drops the PH from 7.4 ish (degassed for 24 hours) to 6.1 daily.
My stem plants pearl well especially past the half way mark on the tank.
My Crypts pearl some by the time the light cycle is over
My Java fern you almost can't see through all the bubbles covering the leaves.
My repens get a few bubbles on the leaves by lights out, but don't pearl very well.
Growth is good, not amazing, but stem plants will grow from just a couple leaves to tank top in 2-3 weeks. Repens fills in well as well.
I have 2 more T5's and I could (without cost) get the par to about 200.
Would you make the change? Would you increase the light?
Thank you,
Whiskey
I have a 75G tank.
I dose EI
Thank you,
Whiskey
